#17 |
Rep Power: 13 ![]() |
Update
I went for a spirited drive through the mountains last night, and today I noticed the sound of a dragging brake from the right rear. Upon inspection there's nothing wrong with the brakes at all, its my rear-axle wheel bearing that has too much play... allowing the axle shaft to actually put pressure on the pads under lateral load in left hand turns. So I ordered bearings for it, should be able to fix that on Monday.
