Go Back   Rotary Car Club > All thing Racing! > AutoX Nuts!
AutoX Nuts! If you are one, post your set up, questions, etc here!
Old 03-02-2008, 12:37 AM   #11
CLH
CLH's Avatar
CLH is on a distinguished road
Originally Posted by Floof907 View Post
What about engine swaps? I want to do some autox with a TII swapped n/a FC, would that bump classes due to technically not being the "factory" engine or would it not matter because you could purchase the same car turbo. hope that makes sense.
Matt
You'd get bumped to at least SM2 since the car didn't come from the factory as a turbo. The only way around that is to *completely* convert the car to a TII, and that means *everything*. Even at that, if you've made other simple mods you'd get bumped out of stock class anyway.
Now, depending on what else you've done to the car you may even get bumped to a Prepared or Modified class (gutted or partially-gutted interior would be the most obvious).
I'd suggest following the link posted above and take a stroll through the rule book, then check back in with whatever questions you have.
Cheers,
Chris
CLH is offline   Reply With Quote
