#2 | |
rotors excite me
You don't even need a relay, just a switch. Most people install the wiring near the fuel pump plug right next to the steering column under the dash. Make sure you solder your connections, don't put it where it could short out, and it should work fine. I don't remember exactly which wire to use, but I'm sure someone knows or maybe rotorwiki has it.
