Old 06-05-2013, 07:40 PM   #11
vrracing
Rotating Assembly
I struggled with the idle setups on our JDM Tii.
I took the TB off to adjust the fast idle. I used a heat gun to test it. I put pictures and descriptions of what I did either on this or the other forum. The FSM is wrong.
The FSM talks about how to set the butterflies but nothing mapped to what was on the TB.
I used that big screw with the sleeve to set the idle. I used the two 12mm nuts on the throttle cable to ensure I had plenty of slack. IMO the engine should start and idle with the cable removed.
Don't forget the ISC. I grounded it straight to the negative terminal as I found that the bolt I was using under the main fuses wasn't working as a ground.
