Old 05-26-2013, 11:59 PM   #11
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Originally Posted by Whizbang View Post
Started swapping the FC subframe into the RX-2. all the old, worn out, garage of a suspension and steering. Made the front brackets are they are welded in. Took forever to get them right using the dial caliper so they should be as close as possible.
Need more cutting discs to clearance the rear. then i can box that and make the rear mounts.
Are the RX2 frame rails the same width as the FCs?
