Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 05-16-2013, 01:03 PM   #11
JhnRX7
JhnRX7's Avatar
I believe what Rice is saying is that using a dyno to rate the performance of your car is ill conceived as each dyno reads a bit differently (even between same manufactures) and it is not accurately comparable. Dyno's are primarily a tuning tool regardless of how the masses actually use them.
Using a V-Box or similar GPS based performance meter you can accurately measure the rate of acceleration of your car. This can then be directly compared to the measured figures of other cars to give you a good baseline of the performance of your car. Granted, doing this correctly is slightly more difficult than strapping your car down to a dyno because you will likely be breaking any posted speed limits and you need a flat stretch of clear road.
