#23 |
I've been Wankeled!
Sorry for the lack of updates on this. I realized I bit off a bit more than I could chew on this so I focused all my attention to just getting things done. I did take some pictures that I'll post for you guys. In the last days of my staycation I installed the rtek 2.1 and routed the palm wiring. I also installed the Apexi AVC-R boost controller and wired it all in. That took a good chunk of time to do. I swapped out my bald rear tires with some fresh ones and I installed the RevTII exhaust. I also installed the rad and wired up the electric fan. I used the factory coolant temp fan switch to trigger the relay for the new fan. I've been picking away at a few small things on my spare time this week too. I got the ABS unit put back in and bled the brakes. I also got my intake piping and AFM mounting all looked after. Just have to get the intake piping welded, sanded, and polished!
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place 1974 Rx-4 all original 27,000 miles 1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place |
