Old 03-08-2013, 07:35 AM   #14
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
Wow I haven't updated this in a while! I took this car to DGRR 2012 and it won 3rd place for best FC. I also found I had a bit of a corrosion issue at my TPS harness connector which was causing a lot of my idle issues and things. The car worked great all last summer and I put lots of miles on it. The time has come though. I'm going to start the major build up in the next few weeks. I already got my KYB/Eibach setup painted and ready to go in and I cleaned and polished my RB RevTII exhaust system. Here's a rough list of mods that will be taking place:
Rtek 2.1 ECU
GSL-SE secondary injectors
Hybrid Turbo
Walbro 255 fuel pump
Custom aluminum intake
HKS SSQV BOV
Emissions Delete
Racing Beat exhaust
Koyo rad and electric fan setup
Braided stainless oil cooler lines
Apexi AVCR boost controller
KYB AGX struts with Eibach springs and RB mounts
Prothane polyurethane bushings
Gauges (haven't decided yet what I want)
That should keep me busy for a while.... Look out for pics of the progress. I'll try and document it as best as I can.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
