Old 02-15-2013, 01:17 AM   #17
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
Too much time not adding more to thread...
too much talking on my part before...
https://www.dropbox.com/sh/v6eq4ls2fn30v4h/YoVpCNVyGH
that is link to all the photos as I update them...
here are some Highlights... (done last summer)
CAR RUNS!!!!
(after some shenanigans with motor related stuff)
put lots of kms on in short time
bought some wicked in-expensive stock rims painted bronze from local member
Bought Touring springs and H&R lowering springs (assembled) form same member for $100!!! again a great deal....
installed replica FEED side skirts and the Shine "rear skirts"
replaced steering wheel
de-powered my steering rack (properly)
doing slow paced V-mount right now
redoing the old interior plastics
installed PLX wideband
turbos not seq boosting correctly (yet)
needs a tune after its all said and done
And helped convert another piston lover to FD owner
Skip to pics...
OR...
Long story (for those readers out there)
Put 10,000kms (6,000miles) on this past summer in just over 2 months... other then my seq boosting problem... she runs great...
Had to pull engine numerous times this summer... once to fix something (for get what...
second, cause dropped something down intake and broke diffuser trying to get it out (The REW will eat diffusers... cause it did... )
put it back in, then while trying to rebuild some compression in the engine, a friend was not being careful when using one of my jimmy rigged tools, and ended up having a piece of metal go *INTO* engine, so...
Third time it came out...
Pulled rear iron, got foreign object out... re-rear ironed the motor.. installed. then started and ran like a Champ.
Friend bought a FD that was in desperate need of some knowledgeable ownership... (the PO used a pry bar of some sort to "remove" various objects off the car.. the butterfly valve in the y pipe has a huge bend in it to match the chunk taken out.. (this is the car in the really Big garage) the car has blown turbos, so he bought a local low comp motor for $500 and is a great parts engine..
Things so far... To do, or have done.
Getting rid of SMIC, In slow Progress of build a Greddy FMIC converted to V-mount. as pics note, its gonna be awesome... Using Koyo N flo (unless someone local wants to trade plus cash for a no name brand one :P)
My goal is to have enough room between the IC rad to sneak in the filters for the Twins.. cause V mounts do a good job, but can do a Great job if the turbo gets fresh air..
Swapped out the ugly efini steering wheel for a later Mazda one, sold old wheel to friend, got a good deal on the new wheel... so that was my christmas present to myself
properly de-powered my rack cause I was getting pissed off always having it off to the side when doing engine pulls. Now its gone, and very easy to pull motor... thats the same reason I got rid of my AC, got in the way too much
Installed a PLX wide band, and matching gauge, into my real, little bit hacked up RE-A steering column gauge holder (thanks Supernaut)
Im redoing all my plastics with Plasti-Dip... was in the states over the summer and picked up 8 spray cans... its over $19 a can here... and just over $6 per can down there... so I sold a few for $10 each. I'm excited to have an interior that will make the car look much more modren cause its not scratched to all hell. Also fixing the Gauge Hood, Jesus bandaid cause I want it to all look the same. so its been epoxied with fiberglass renforcement, and now sanding down to make it look as nice and pretty. (see pics)
After the V-mount is done, and I have her running again, I'm going to dive into the engine and find out where I screwed up on my emissions removal/wiring harness redo/vacuum line redo.
and fix that Damn things, so they spool perfectly... Also installed to Prosport Manual Boost controllers so I can eliminate the wiring/solenoids/vac lines, for those two and Simplify things a bit...
Once its boosting properly, it going for a tune.. maybe to local tuner for a base tune.. then I'll post it up on the Datalogit group i'm in and see if the local guy knows his rotaries or not...
then I'll get there help to Fine tune it.
Then water/meth injection as per Mr Rice's recommendation... (would like to do preturbo on both twins... if possible while keeping the Airfilters)
only person I've seen do it so far.. is from the 7 club (look at his engine bay pic) I want to keep the air filters on...
http://www.rx7club.com/time-slips-dy...record-971246/
Pictures!!!!
Link to them all..
Thats the Link to all of them..
Here are some Honorable mentions with quick caption...
at local Mazda Dealer, loving on the new ladies
wide band install and brother business shop after hours...
this reminded me of this...
Put away for winter in tiny garage im renting (cousins garage)
New wheel installed... look at album for old wheel pictures
me getting serious business while wearing Wankel Mechanic shirt, after pulling a few things to start fabbing V-mount
mostly sanded plastics... hood is not done due to needing to be fixed... hence the Band aids and Jesus Bandaid on them earlier...
FMIC ----> V-Mount dreaming/early test fit mock up...
My Uras Front Lip (probably going to plasti dip black...)
cause I like
to whore it out...
local car imported with same lip.. I HAD the only one I knew of in North America... guess not any more...
nice car though...
Rims and Springs shocks I bought from Local 1.5 hour away, Member for $100 for each set!!!!
There are a few other pictures in there as well...
one last one...
This is Lee ("Project D1" on 7 forum, with super wide and low CW 94)
Thats all for now...
Comments are welcome... I just dont want a shit fest... lol
PS. feel free to give me shit for taking to long in the future....
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
adaptronic, efr 8374
