Old 01-08-2013, 03:19 AM   #11
JustJeff
JustJeff's Avatar
I swear it looks like oil dripped down from the oil filter / base?
Any leaks on the oil pan itself?
It could be an oil leak could've seeped upwards?
Yes and yes, I'm using an oil pedestal sandwich for my temp and pressure senders. I did initially have problems with the sandwich leaking, which I had addressed. I also had a leak at the oil level sensor on the oil pan. I wasn't sure if the sensor that came on my JDM engine was working or not so I swapped to a known working one. I did not think to replace the oring and had a consistent but small leak from there.
I didn't not see any oil had run down the bellhousing of the transmission, but I think I know where this is leading. Oil from the pedestal leak worked its way between the rear iron and transmission?
Originally Posted by yzf-r1
