Old 11-30-2012, 10:36 PM   #2
eprx7
eprx7 is on a distinguished road
I wouldn't put a fuel pump that far up stream in the fuel system. It would take quite some time to prime it also you are dealing with higher temps under the hood.
Why don't you just put it in the same location as the old fuel pump?
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
