Old 09-10-2012, 03:21 PM   #11
85turbo12a
nerd
85turbo12a's Avatar
85turbo12a is on a distinguished road
smoothed off all the sharp edges of the stock pistons, a FYI for anyone considering this engine, the stock internals of the early 1uzfe engines 89-94, are good for near around 600 crank hp and safe to 7k rpm, its recommended to NOT exceed 7500 rpm due to rod CAP failure, and cam tappet shim issues, since its a shim over bucket design. the early engines have MUCH thicker rods for use in turbo application. the 95+ rods are pencils and will break.
settled upon a twin turbo set up, as soon as i finish assembling the engine and start fabbing plumbing I will post pics of the engine bay, im very anxious to hear what this engine will sound like through the twins and into the big single pipe...there will be no hiding its piston engine-ness from rotorheads....but unless they hear it, there are external clues.
i do still want another rotary...just not a turbo...too problematic...would like a nice NA rx3 or something, really like rx3 SP....cant afford one...
85turbo12a is offline   Reply With Quote
