Old 08-14-2012, 05:44 PM   #11
PSI
PSI is on a distinguished road
PSI or JZN otherwise known as Green Brothers in New Zealand not shy to post his copy of my water injection ideas here > LOL > http://www.rx7club.com/showthread.php?t=974884
Shame he got all shy and can't be fucked updating the thread here since I know who he is
This is a common mistake for newbies thinking they can run water injection without a CDI ignition system, I read about how you dented your rotor, and make more power by reducing water, the problem you have is you are letting the motor dictate to you how to run due to the lack of ignition power and not you dictating to the motor how it will run safely.
The splitting of your water tank is another common newbie mistake, if you pay close attention to my WI thread (which I know you have!) you will see the detailed construction of my water tank, it is CNC folded and has not welded seems at all in its construction the end caps are folded over and lap welded. This is the only thing that lasts long term in the pressure ranges we run, also you need to use very thick plate, not light shit most cunts use.
I STRONGLY recommend you switch over to WM50, it is vastly superior to running just plain water, again you can experiment yourself on this but I will safe you allot of time and more broken engine parts
The water jet you think you have copied from me is nothing like what I run you will need to work out your quantities for yourself.
The mac valve will work with WM50 not a problem, I know I have been using it for a lot of years with my customers and myself in my own car for the last 2 years.
You are really wasting your time bouncing off ideas on rx7club, they are just a bunch of useless cunts over there with not one idea of much at all.
Feel free to come good on who you really are and feel free to share information here, I am willing to help anyone who is up front and not too scared to hide behind the internet
Best Regards.
I don’t mind if you know who I am. I’d actually forgotten about this thread.
To set the record straight, I did not copy you. I got the idea and basic design from a friend and rotary pioneer in NZ (RIP) who ran water injection in his 13B turbo powered 626 back in the early 80’s. His set up sucked through a sidedraft Weber and he used boost operated pre-carb (pre-turbo) water injection to allow more boost with the hi compression rotors of the day. His water injection idea came from WWII fighters as he was an avid aircraft enthusiast and pilot, even becoming friends with an ex Luftwaffe Me109 pilot on one of his trips abroad (he was sent to Germany and other places by the NZ Govt to look at alternative engine technology during the oil crisis of the 70’s).
Other than the info from my friend, I have read about Pratt & Whitney’s work with water injection, and found some good info on Rx7club by Howard Coleman and a guy ‘rx72c’. I only became interested in water injection a year and a half ago because up until then most of my experience had been with n/a engines.
So I guess if you are accusing me of copying you, then everyone with pre-turbo water injection must have copied you right? Realistically, everyones pre-turbo setups are going to be very similar anyway as there are only two ways of going about it – boost operated or elec pump. I went with what I think to be the simplest and potentially most reliable set up. It is also the cheapest setup as I’m on a tight budget.
PSI is offline   Reply With Quote
