Go Back   Rotary Car Club > REGIONAL FORUM > Canadian RCC forum
Canadian RCC forum All Of Canada
Old 06-14-2012, 03:15 PM   #25
justin lilley
20B
justin lilley's Avatar
justin lilley is on a distinguished road
After the Body Shop & New Paint > http://www.dodo-logic.ca/?p=10868#more-10868
It is a Force Fed Built... 1993 Toyota 2WD ,Extra long ,wide bed . Club cab , Pickup ..with a 13B Cosmo Series 6 engine ,it has the oversized intake and Exhaust ports ( stock ) She Makes... 330 rwhp & 310ft-lbs of torque @ 16psi on Pump gas ..The power band is from 3000-7500 and totally set up for towing!..
Turbo is a a Holset HX-35 .... Transmission is ..Toyota R151 5 Speed (RWD) Manual Transmission ..... Differential is ... a one ton rear end (toyota) That is the larger 8 inch with a 4.1 Eaton LSD is true LSD. and rare 5 bolt 30 spline HD axles. .... Wheels are Supra tt 95 wheels. The offset is +50 8.5 front and 9.5 rear.
http://s791.photobucket.com/user/jus...48524423662999
justin lilley is offline   Reply With Quote
