Old 05-26-2012, 08:34 PM   #6
mazpower
Rawr Bearclaw
mazpower's Avatar
Get the RX-8 shaft and both front & rear RX-8 stationaries with bearings. Nothing needs to be done with the oil passage. If you're using non RX-8 stationaries/bearings be sure to use a dial bore gauge and mic's to verify your oil clearances.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
