Old 05-05-2012, 03:10 PM   #19
Originally Posted by Raksj04 View Post
I had the issue of hesition and wild AFR fluxs when the car is in the closed loop mode. I have a RTEK 2.1 walbro 255 and larger secondry fuel injectors. From what I have read increasing the fuel pressure or just upgrading to FPR to one that can handle the increased flow of the fuel pump will fix the issue. I do plan on getting a fuel pressure gauge with this setup.
There's your problem
Originally Posted by Sharingan 19 View Post
Your lean afrs during cruise are not caused by the stock FPR or its lack of adjustment. The Wlabro 255 will outflow the stock FPR and if anything will cause a rich condition, not lean. Raising your static fuel pressure might mask the problem but that's no the same as finding the real source.
Except that walbro's, whinboros', walsucks, wilpuke, all those pumps are HORRIBLE pieces of crap. I wouldn't trust one on an n/a car. Garbage
Lean isn't the issue it is the 2 to 3 lamba bounce I get at cruise that I worry about and I am trying to fix.
You don't understand Lambda, do you?
bouncing between what and what? (in afr please, when did we start talking about lambda?)
We can't be, mathematically a 2-3 lambda bouce would be 29-43:1
bounce from 12.0 to 16.0
That's AFR's, not Lambda. Lambda = actual AFR/14.7
