Old 04-18-2008, 11:31 AM   #23
What did you do about the above stat gear (bearing)?
I forgot to tell you to...molest it.
Feel with your fingers to see if you can detect any change of the surface.
If you can feel anything, I would recommend to change it out.
Replacement bearings are not that expensive ($20?); labor usually costs more to press it out and then replace.
Good luck!
