Go Back   Rotary Car Club > Multimedia > Videos, Photos, Manuals, > 3rd Gens
3rd Gens Videos, Pics, etc of 3rd Gens ONLY!
Old 04-20-2012, 04:01 PM   #20
forcefed7
forcefed7 is on a distinguished road
For the motor:
It's bridge and peripheral ported
-Semi PP with street port.
Ceramic apex seals
-no, 2mm steel
What exact turbo specification?
-GT4202R
fuel system detail?
-6 x 160lbs injectors
race clearanced rotors?
-yes
what compression ratio?
-slightly less then 9:1
what crank shaft if not standard?
-reworked stock mazda shaft
How big is the exhaust system post turbo?
-4" with two muffler
is the waste gate plumbed back?
-no
Pro EFI (how good is it) on staging it has a mis in the video? *see note on fuel system specs*
-Very good, still needed accel table adjustments
what exact fuel do you run in it?
-93 octane, VPC16, or Q16
what AFR
-whatever the engine needs depending on load.
What ignition system?
-inductive ignition system.
how much timing on 350kpa ABS?
-whatever the engine needs depending on load and charge density.
Congrats on the power and the nature of it, it is exceptional
If you e-mail me I'm sure I will get you a tester shipped from one of my friends there asap
forcefed7 is offline   Reply With Quote
