both are pressed in, thought the coolant nipple will probably be rather hard to remove. The oil pedestal can be removed by tapping with a hammer/block/whatever from the bottom.
Was the nipple crushed shut or just sealed with jbweld or something? If you are careful you could maybe drill through it, etc.
