Old 04-16-2008, 03:09 PM   #2
josh18_2k
this may not be the cause at all.. but any good MBC is vented, to prevent boost fluctuation. on mine, there was a small hole drilled into the part with the ball/spring. i'm thinking that the tiny bit of air sucked in through the vent is contributing to your drop in vacuum, and is totally normal.
if im wrong, my bad
