#136 |
The Judge
My Triumph Daytona fast sensor is made a little different. The sensor is surrounded by a brass tube which is an extension of the brass base.
The brass tube has a few holes in it to allow a little flow of air through it. This way the little expose sensor does not get the direct blast of air on it. Unfortunately the place I got mine, no longer carries it. And when I search for it, I can not find it. Part # is T1900510 while dudemaaan's is # T1290510. Got it from: http://speedsupplies.com/partslistin...00&category=TM |
#137 | |
Don Mega
#138 |
wannaspeed.com has a few more of the sensors in
500+ HP thanks to: ![]() Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
#139 |
Banned
I've had no issues with quality or durability of the wannaspeed sensor in my car, but it doesn't respond as fast as I thought it would - still better than stock, so I guess that's what matters
#140 |
The sensor responds pretty much immediately. If you aren't seeing quick changes in air temperature readings it's probably because the air temperature isn't changing rapidly, at least from where the sensor is reading it. In my bench testing just breathing hot air on it caused rapid changes in resistance. You might also make sure the sensor is clocked properly so the air flows through the plastic square area rather then into it. Not sure if it makes a huge difference or not but maybe.
#141 |
mazda used an open element iat's on the second gen rx7's
#142 |
The Judge
#143 |
Viable Fossil
As to durability, I've had my wannaspeed sensor now for about 30,000 miles. Relocated pre-throttle-body. That's close to 50,000 kilometers. Still functions as new.
I know two others who've had the sensor for a few years. No reported issues.
Jim VR R1 FD Last edited by Signal 2; 01-13-2012 at 07:05 AM. |
#144 |
What size are the threads on this? 1/8 npt?
#145 | ||
Half bubble off plumb
Rep Power: 17 ![]() |
I know this might not answer your question, but they are exactly, the same size, and thread as the OEM sensors... Making them a drop in fit...
J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#146 |
I have a custom manifold that doesn't have a port yet, so I'm trying to figure out which bung to weld on.
#147 | |
Viable Fossil
As for what thread size, just take it to a hardware store that carries metric and find a nut that will work. It's metric, but not pipe thread. If I get a chance to get down to my shop I'll try to find my old OEM IAT and see what size it is...
Jim VR R1 FD |
#148 |
Thread size is M10 x1,25 if my mind serves right
#149 |
#150 |
DIGG7ER
I just tried to order this and they're currently out of stock since the supplier stopped supplying the sensor
EXCELLENCE IS NEVER AN ACCIDENT, IT IS ALWAYS THE RESULT OF HIGH INTENTION, SINCERE EFFORT, INTELLIGENT DIRECTION, SKILLFUL EXECUTION AND THE VISION TO SEE OBSTACLES AS OPPORTUNITY...
