Old 09-26-2011, 05:33 AM   #4
Pete_89T2
Pete_89T2's Avatar
Originally Posted by JustJeff View Post
Yes MBC= manual boost controller
My plan was to depin the wiring for the solenoid at the ECU. That would keep me from getting any CELs. My understanding is that if you have aftermarket boost control you want to remove that solenoid. But you have kept yours. I'm assuming you are running bigger than OEM turbo boost and that you also have some aftermarket boost control?
If you depin the solenoid at the ECU, it will still see it as an open circuit, so I'd guess you'll still get the CE light.
I probably should start another thread to ask about boost control. Right now, I'm still running the stock boost control solenoid setup, and unfortunately the Rtek 2.x doesn't let you tweak the boost limit. My setup boosts up to about 8.5 psi with a turbo & exhaust setup similar to yours - BNR stage 1 turbo into RB DP, RB presilencer & Borla catback. With the BNR turbo wastegate porting, the stock boost control is very effective - it spools up quickly, and consistently doesn't go beyond the set boost limit, with no creep or spikes seen in the logs. So now I just want to raise that boost set point a little bit to about 10psi.
