Backyard Mechanic
I took off my oil pan to install an oil pan brace and I found this. Ive yet fully disassemble a rotary engine so I am at a loss on what it is
, and it has me scared that I will need an early rebuild.IMAG0197.jpg |
Rep Power: 15 ![]() |
Did you also find a small ball and spring to go with it?.
Backyard Mechanic
No, but thats not to say that the ball and spring did not fall out last time i changed my oil. shouldnt there be a hole in it if it was the oil jet?
Rep Power: 10 ![]() |
That was my question too
Backyard Mechanic
This doesnt look like the pics of oil jets Ive seen
Looks like some of the actual oil jets that I've seen though. Not to mention there's nothing else in the engine that looks like that unless something fell down the oil fill.
It does look like an oil jet set screw...from the eccentric shaft?
Does it have a hole in the center of it? -Ted |
Backyard Mechanic
shoudnt there be a hole in it? or is it just microscopic.
#9 |
Backyard Mechanic
Well I am pretty sure that it is the oil pump lock screw, but what is its purpose? Can i just take off the front cover to replace it?
#10 | |
Forgot about that oil pump screw..... how would that back out unless it was installed improperly? And is it infact that?
#11 |
I've been Wankeled!
If it's a jet from the e shaft you'll have to pull the whole engine apart anyway. Might as well start by just removing the front cover and inspect the oil pump. If you don't find anything there keep moving on with the tear down. Good old exploratory surgery......
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place 1974 Rx-4 all original 27,000 miles 1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place |
#12 | |
Backyard Mechanic
Yea, thats what Ill do |
#13 |
Isn't that the retaining screw from the stat gear bearing? Or is there one on that engine? Dunno??
#14 |
Rep Power: 20 ![]() |
I was wondering the same thing.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#15 |
Home-brew Rotary
I would do the exploratory surgery as well.
Take engine out, take front cover off, inspect things under there. Then if not any problems found there its rebuild time. The least you'll need is new coolant seals. But I wonder how the hell does an oil jet from the e-shaft even make its way to the oil pan? Makes me think its got to be from something under the front cover.
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
