Old 07-15-2011, 03:10 PM   #7
Honestly unless you are wanting a 500whp beast I would stick with a FC TII swap. The engine drops in perfect with a GSL-SE cover and oil pan. Just tap the front cover (which already has a depressed section where the oil line goes in and bam good to go. Trans crossmember can be custom fabbed by a member on here who sells them. Then get a custom driveshaft and your set. Its a stupid easy install. I did mine by myself at the age of 17.
