Old 04-06-2008, 10:00 PM   #2
ZGN
Administrator
ZGN's Avatar
Ignition breakup, Stumbling at boost. you probably can do some test on it via an ohm meter to test. also with the PFC you can advance or retard the Leading or trailing @ idle to test.
you should know this lol you convinced me to go with the HKS TP! it works great with a new coil!
