Backyard Mechanic
Fuel hard line adaptor
I am converting my fuel lines to -6 AN and I know some guys used this adaptor
http://www.summitracing.com/parts/EAR-165056ERL/ My question is do you flare the hard line 37 degrees like the tube sleeves? |
That particular adapter fitting is only for aluminum tube / pipe.
I don't think you're supposed to use it with the stock OEM (coated) fuel line. This is pricey, but you can try this: http://www.summitracing.com/parts/AEI-15103/ -Ted |
Backyard Mechanic
Based on this site
-http://www.honda-tech.com/showthread.php?t=1527379 I can use earls Part # - 581805 - 5 an tube nut and Part # - 581905 - 5 an tube sleeve but I cant find what psi they are rated at. I think I am going to a hydraulic shop today that uses Aeroquip products and ask them what they think. |
Backyard Mechanic
I just got back from the hydraulic shop and they gave me the Eaton equivalent to those Earls part numbers.
Tube sleeves, -5 AN tube nuts, and -5 AN to -6 AN adapters. |
The fan hit the shit!
^ you prob only spent a couple of bucks too compared to hundreds of dollars compared to those shiny blue/red fittings. lol. It's soo funny how much cheaper and better quality fittings you can get from a local hydro shop and most ppl don't even realize it.
Zack |
Backyard Mechanic
Very true
