Old 02-18-2011, 09:41 AM   #1
MotoTek
Always Under Construction
MotoTek's Avatar
FS: Brand New 13b-REW (0-Miles)
$3250.00 Shipped No core needed/wanted
I say brand new because every spring, seal, and bearing has been replaced with new OEM parts, with the exception of upgrading to 2mm Rotary Aviation Super Seals & using the Atkins Thermal Pellet. The motor was built by Ben/Karack @ Rotary Evolution, one of the most knowledgeable people in the rotary community today, search for him. The actual rotor housings and rotors were used as they came from a very low milage engine, so it didn't make sense to replace something that was pretty much new.
This is for a short block, but I should have everything for a long block if needed, pm me and we can work something out.
ENGINE SPECS:
Large Street Port
RA 2mm Super Seals
OEM Corner Seals
OEM 2mm Apex Seal Springs
OEM Corner Seal Springs
OEM Side Seals
OEM Side Seal Springs
OEM O Rings
OEM Oil Control Rings
OEM Oil Ring Springs
OEM Front Seal
OEM Rear Main Seal
OEM Pilot Bearing & Seal
OEM Rotor Bearings
OEM Stationary Gear Bearings
Apex Seals:
http://i129.photobucket.com/albums/p...l/DSCF5030.jpg
Engine Porting:
http://img198.imageshack.us/img198/6...cture048lc.jpg
http://img692.imageshack.us/img692/5256/picture052p.jpg
http://img682.imageshack.us/img682/7...cture054ss.jpg
http://img820.imageshack.us/img820/567/picture055j.jpg
http://img62.imageshack.us/img62/589/picture056p.jpg
Engine Pics:
http://i129.photobucket.com/albums/p...dl/engine1.jpg
http://i129.photobucket.com/albums/p...dl/engine2.jpg
http://img683.imageshack.us/img683/439/picture057nn.jpg
Engine is a fully assembled short block, minus an oil pan. Here's how it sits right now, on the engine stand. I've wrapped it in cellophane to keep moisture out.
BLACKADDE™ | ADGT RX7 |
