#496 |
Bah!
I replied to my thread on the denso pump, but I'll put it here as well
I got mine brand new for $190 shipped from www.TitanMotorsports.com Everyone else was backordered, the folks there had it shipped to my door in about 5 business days (It'll be quicker to you since they're in Florida) I initially purchased it for 149.99 shipped from http://densofuelpump.com/index.html , but got a refund when I found out it was backordered. If you can wait, these guys are cheaper.
Johnson TA FC in the works! |
#497 | |
Rep Power: 10 ![]() |
Thanks Johnson, but when I checked Titan, they had it for $235?
And that Denso Fuel Pump.com place that you're referring to has a neat little disclaimer underneath it... did you see that? These guys right? http://densofuelpump.com/index.html Quote:
One Time fit kit has the pump, lines, and filter.... I might just end up going that route again.
#498 |
Bah!
I bought it from their ebay store, actually. They had it for $190 shipped, comes in an authentic Denso Box with all the fittings, adaptors, and new fuel filter.
http://cgi.ebay.com/ebaymotors/Denso...#ht_3324wt_954
#499 |
Damn B.... Why not just build your own pump though
#500 | |
![]() I thought about it, there's no pump out there that flows better than 300lph that's quite............. MAYBE.... I have a plan. @ 70 psi the Denso is right on the cusp of being overdrawn by the injectors. If this is the case, it's time for a Kenne Bell BAP to get it up and over the hump. It's really got me thinking about WTF I'm going to do about the FD though. That's going to need more fuel than the Denso can put out. That'll be an interesting project.... twin in surge tank Denso's ![]() Ya know, when you think you've done everything, and over done it right....... this shit happens..... Oh well. I'm heading out to Dave's on Thrusday and kinda want to have this little issue sorted out so next wed (next day off) I can pull the engine make a few changes, bolt on the 6-spd, swap the 4.3 in and then maybe finally get over the dyno hump. When are you looking to head out Bill?
#501 |
Rep Power: 20 ![]() |
Damn you and your projects that get completed in timely manners!
#502 |
Yup
![]() So I "tested" the Supra TT pump... unrestricted it will fill that 5 gal in about 3:05. It flows 97 gph or 367 lph ![]() ![]() ![]()
#503 |
F yo couch!
Rep Power: 17 ![]() |
hell yea dude, why do you think all the FD guys use them?
as the saying goes, that ive heard at least,....its the only the toyota built right
87' n/a FC 94' FD-360whp, 300lbs-tq at 14psi on twins 92' ZZR-600 sold 07' CBR600RR more to come
#504 |
Wow, over a week since an update... ok, so here it goes in a quickie
Got the fuel cell working tip top. The old cosmo pump that I had actually turned out to be good. Tested right where it should've, 252lph @ 43.5 psi. Cool, so that's in the lift pump position, and the supra is in the surge tank position. So far everything seems to be awesome. I built a bunch of harness adapters and clear tubing to monitor V, A, and flow and it seems to be working as it should. The last little piece that I need to build is an overflow/recirc tank if you will that I plan to mount high where the spare tire once lived. I didn't really take into account thermal expansion when I designed the damn thing. The fuel is coming back hot, expanding in the tank, and puking out the vent. Bad. The solution is about a gallon tank mounted above the cell itself. In theory the fuel can expand into that before it heads out of the vent. When the level in the tank falls, the fuel will siphon itself back into the cell. Hopefully that will cure the last of the woes with this little project. Got the 4.3 Torsen swapped in yesterday as well as hauled the engine, cracked the pan off to remove the shims in the bypass valve. Pressure was WAY too high. FD reg + shimmed bypass + ported galleys, + o-ring sealed pump + cold 10w30 = 150psi cold!!! So the shims came out and everything is being buttoned back up. Also pulled the engine to FINALLY install the 6-spd. It'll be alot easier to mount the slave cylinder (that will be a modded S4 TII unit) with the engine/trans out of the car. Then stab it back in and build a mount. I made a simple jig that fit's between the u-joints and the trans tunnel and the u-joints and the floor to position the trans/engine exactely where it was with the S5TII shit box trans. This way I should be able to get everything exactely where it wants to be. I should have everything up and running in a few days. I was hoping to get a few hours in on the girl tonight, but the 13.5 hr work day had different plans. Tomorrow is out as well as it will be a 15+hr day.... ugh. maybe Sunday... I'm only expecting about 10 Oh well, what can ya do except continue to bust ass.If all goes well, Dyno on 8/7 and auto-x on 8/8..... fingers crossed ladies
#505 |
You better be there 8/7, lol.... none of this calling me the night before telling me you're not sure if the 'ol girl will get done in time
![]() I'll check with MC to see if he is good for that day too, I mentioned it to him but we hadn't firmed it up yet so I'll get back to him and see (if of course, he's not reading this thread).. Oh, and thanks for all the annoying/dreadful research and work into fuel systems, I think you saved me several hours in my project when I go to do it... I'll start with a supra pump
#506 |
GL fellas I'll be getting laid that night (anniversary and all).
#507 | |||
Boost get's you laid, 400+ rwhp makes panties wet. This is fact Congrats man.
#508 |
Member of the D club
Wait, you have an FD now? I gotsta go back and find where I left off on this baby.
#509 |
F yo couch!
the FC LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
now i just have to waste another weekend, borrow abdul's diff and bring the FD back to life!! btw, kel wants to know when u have a free night to fix his exhaust, just let me know when u have a chance buddy
#510 | ||
Dunno, hopefully sometime next week. Actually going to try to hook up with Abdul on Monday and grab those seats from him. How close do the two of you live to each other?
