Old 06-19-2010, 05:29 AM   #11
Stredrotor
Stredrotor is on a distinguished road
Hey guys, today I moved the wastegate outlet which fouled on my new radiator .
Cut it off and shortened it........
Then welded it up!
The pipe from the barrel cooler to throttle body now welded.
I made a mount for the coils. I think they should work there .
Here's a pic of the dump pipe, just tacked up at the moment. When I get the lower flange cut and tacked I can see if the flange will fit past the engine and steering box .
Then I can weld that up as well.
RX4 coupe 20B conversion http://www.rotarycarclub.com/rotary_...ead.php?t=9884
Stredrotor is offline   Reply With Quote
20b, mazda rx-4
