Old 06-15-2010, 08:08 PM   #13
NoDOHC
NoDOHC's Avatar
Hey Buggy, I am curious what you get on the dyno with your setup. That will be interesting to contrast the power band of that engine to the one that I posted earlier from mine. You probably have a naturally better intake, but I am mostly interrested in low end, torque curve, etc. Also, what do you get for fuel economy?
To the original poster: Go 4-port FTW! I was worried about losing low-end going from a 6-port to a 4 port, but the 4-port stomps the 6-port above 1800 rpm. Meaning that you get better grunt, even on the interstate in high gear. Idle is good and mileage doesn't suffer much (35mpg 6-port -> 30 mpg 4-port with NA 5-speed, 25 mpg 4-port with turbo 5-speed).
The 4-port is easy to work on (all kinds of space where the turbo is supposed to go), runs cooler (could be from the lower compression ratio) and is much simpler to tune.
The only thing I would do differently if I ever get a chance would be to use NA rotors instead of turbo ones. I don't know if the small weight savings and additional 3 point on the compression ratio makes it worth the expense for RX8 rotors or e-shaft.
