Old 06-15-2010, 06:43 PM   #9
Originally Posted by FerociousP View Post
Isn't there a need for a gasket there? What I mean is there are the two washers on the studs to the left to keep the water pump housing level right, and not having those, or using those and not a gasket might not let the housing flange sit level with the block.
** With that said, I haven't tried it, that's just what I've heard/thought was going on. Mazdatrix mentions the housing will break without them.
Reted correct me if I'm wrong!
You are right.
If you don't have the even pressure (stock uses the gasket + two thin shim washers) on the water pump housing to the front iron, there's a possibility you can crack off the top-most water pump housing stud "ear" on the front iron.
I've seen it countless times.
Yes, in a pinch, I've used just RTV on the mating surfaces *PLUS* the two water pump housing studs that would normally have those two thin shim washers.
