Old 05-26-2010, 04:41 PM   #8
89Rotary
GTUs 6 Port
89Rotary's Avatar
89Rotary is on a distinguished road
Honestly I could tell you some numbers, but there's really no need for a few reasons:
You can not tune fuel with a NB. It can only tell you if you're off stoich (rich or lean), but can't tell you how much. IE usually making peak power at a 12:1 AFR (or 0.8 Lambda). Consequently the timing is more sensitive to what type of gas you're using. If you're using regular (as stated by the Owners manual) stock firing is fine--can verify by strapping it to a dyno and going from there. If you want to adjust timing, you'll need to put it on a dyno (don't go by feel), and slowly adjust it from there. Depending on your spark energy you should see some decent gains (don't forget to go to a higher octane rating when you adjust it).
I understand all that. but, Being as i have a Large Street Ported Motor, Factory timing isn't correct anymore right?
Jake B "Built NEVER Bought"
1989 Mazda FC3S GTUs
TII Swap In Progress
"Days Of Spoken Legend Has Come To An End, The Curtain Of The New Rotary Era Has Been Raised"
89Rotary is offline   Reply With Quote
fuel tuning, rtek tuning
