Old 05-04-2010, 12:57 AM   #11
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
Originally Posted by Mobius View Post
Sorry to hear this. I had something similar happen to me. I could not get fuel to the car, the fuel pump relay would not energize in either the start or run ignition modes. I ended up jumpering it out from the diagnostics box under the hood. It got me home, and come to think of it, I haven't fixed that problem yet either.
Thank you sir!!!! thinking back to it, that could be a way to help narrow down what the issue is...
cause it could be that the stock relay for the Fuel pump is not getting a signal from the ignition, there fore, no fuel pump...
but when I ran the diagnostic test I could clearly hear the pump going... when with just the ignition on i heard nothing..
if that is the issue, then its just an easy fix... run a new signal wire from ignition source, and run power from battery to a new relay... this would also be a way to upgrade the power going to the system, thus allowing the pump to get a bit more voltage, and flow a bit more..
I was hoping to Make it to the AGM yesterday, but left late due to trying to eliminate something off the board...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
adaptronic, efr 8374
