Old 02-16-2010, 03:21 PM   #10
classicauto
crash auto?fix auto
classicauto's Avatar
from my experience straight washer fluid doesn't alter the wideband readings. Assuming you're not spraying LOADS in there. I used up to 625cc with no real, quantifiable, change. Straight meth on 625cc would richen up consistently .2-.3AFR.
Straight water is what I run mostly, wouldn't think of using anything else if its saftey you're after and can keep freezing in check.
