Old 02-10-2010, 05:30 AM   #3
Originally Posted by Rx-7fetish View Post
i also need to know where the vac line from the BOV, and the pressure sensor goes on the motor i think i got it backwards. I want all this straight before i try to start it after like 3 months lol
Stock wise...
The stock boost sensor goes to a fitting on the ACV valve.
The stock BOV goes to a fitting on the flange on the upper intake manifold that mates with the lower intake manifold - this fitting is hard to see, cause it's under the stock BAC valve.
If you blocked off your ACV, then you just lost one of the fittings.
