Rep Power: 21 ![]() |
Air filters for ITBs
so i am kinda stuck on how to get a functioning air filter on my itbs yet still maintain the benefit of the ram tubes....
the closest ive found where socks that go completely over the horns. I've been trying to find filters for inside the horns as well.
heres a link to the socks http://forums.club4ag.com/zerothread?id=26038
![]() 85 rx7 gsl-se - AA tags/ never ending project will never run |
now what?
Rep Power: 17 ![]() |
http://www.tweakit.net/shop/product_...roducts_id=450
these would work, wouldnt they? only place ive ever really seen them.
1986 Rx7 coupe - arctic silver - sold aka - 20bforme |
Ram socks work, but something like this: http://www.efihardware.com/products/...mm-ida-3.25-KN is probably closer to what you're looking for.
I used a Weber 48mm IDA carb to good effect, and I had a similar (and much cheaper) filter canister on it, that allowed the velocity stacks to extend up into the filter area; as that throttle body is an IDA style, and therefore the spacing should be the same, I wonder if a Weber IDA filter could be made to work with some mild adjustment? |
An airbox is by far the simplest. It will also give you the possibility of taking in cold air from outside rather than engine bay air that you would get from the socks.
KTEC
a friend of mine just used some filters from a snow mobile. they look basically the same as a cone filter that comes on just about every regular intake. but instead of being huge, its ITB sized. they sell them on eBay...
Pipercross is what our customers use. We use them for the street on our car. We do carry them. We have also carried these nets that do not filter the smaller stuff but are popular.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car Last edited by FujiRacing; 12-20-2009 at 08:18 AM. Reason: Attach pic |
how much for the pipercross? its dust here so screens arent going to cut it
#9 |
Pipercross is $55.00 for the pair plus $4.95 S&H.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car |
#10 |
will they fit my efi hardware itbs? any pics?
#11 |
i looked online and i think i saw what your talking about on their site and im pretty sure that is the way to go. How would i go about paying you?
#12 |
You can reach me directly @ 352-217-5554 or email @Fujiracingusa@aol.com. Thanks!
#13 |
No offense, but pretty much any arrangement where you have a small filter on the horns, well, sucks. If you look at factory ITB setups on BMW's and such, they have one thing in common, they use a plenum. That is what I suggest that you do if you want it to perform as best as possible. This allows you to do 2 things, for one, you can take "cold" air from outside the engine bay and feed it to the engine, but secondly, you can get more filter area and get it away from the TB's, reducing the turbulence and giving better performance.
#14 |
to make that work it a bit more involved that it sounds. i just need something to cover the air horns for now. I eventually DO want to go with something along those lines, but that will require some ingenuity since there is nothing "ready to go" to make that work.
#15 |
I agree a plenum box will be better than the sock type filters but there is alot of work and cost involved.
