#11 | ||
Rep Power: 10 ![]() |
Exhaust - an equal length mani, each with a wastegate and an internally gated turbo just to give the turbo the chance to vent out as much exhaust energy as possible. The two individual gates will plumb back into the exhaust AFTER the second larger turbo. The larger turbo is also internally gated. Intake - First, I'm undecided if the intercooler will be a dual inlet or not. For simplicity and to give the first turbo the least amount of space to pressurize, I believe the turbo's will be merged as close to the first turbo as possible and an electonic cut-out will be utilized. So, the first turbo is plumbed strait to a merge collector. The second turbo is plumbed to the merge collector as well but inline is an electric cut-out to keep the first turbo from back-spinning the second. There also needs to be a vent to allow the turbo to spool without creating a TREMENDOUS amount of exhaust backpressure. Control.... well I'll be using a Motec M800 so the control's are virtually limitless. I'm thinking there needs to be a 3d map setup such that when MAP = the charge pipe for the seconday turbo, the valve opens and the vent closes. Easily accomplishable. Two different WG controls but the closed loop being on the larger turbos internal gate and the WG on the mani's being run off duty cylce at a preset limit to control "absolute boost" Thoughts?
