Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 06-10-2012, 08:29 PM   #31
Garfinkles Motor Works
I can make a set with JIC # 6 fittings for the twins.Do the new BNR s use the same gasket pattern as the stock twin .If no send me a gasket for a pattern .I have the programs for the T04 flange .
Why would yzf r1 be on my list ?
Old 07-20-2012, 01:19 PM   #32
Monkman33
Still Building my FD
That message is in my sig, not referring to your settings at all. So no worries on that. :-)
Also, I am wondering if you are still making these?
I am also considering having the rear return be split so I can run a vent line off the top of it to prevent oil from filling up the intake/catch can. What are you thoughts on this? I have seen people use the rear return port for this purpose with single turbos and I was thinking it would be an effective way of getting the same benefits with twins. any thoughts? and do you think it is possible?
Uh.... hi.
Old 07-23-2012, 12:27 PM   #33
Smokey
Long Time Onlooker
Smokey is on a distinguished road
If you do this and it works please post it up. I've been searching for a solution and it seems the only one I've come across is to run a baffled oil fill neck and run the car about 3/4 of a quart low on oil which I don't like.
93 Touring - AD coilovers, BBK, full exhaust, PFS SMIC, PFC
Smokey is offline   Reply With Quote
Old 07-26-2012, 08:15 AM   #34
Monkman and I are working on a design, if there is enough room I can make the part .
Old 07-27-2012, 12:17 AM   #35
Monkman33
I am looking at my twins to see what type of setup would be best. I will have some concepts and pics sent to you tomorrow hopefully.
Uh.... hi.
Old 08-17-2012, 09:14 AM   #36
I hope the parts I made for you work ,if not we will do the over untill they fit .
