View Poll Results: How Loud am I going to be?
Cops will pull you over without even seeing you 2 28.57%
Cops will have to see you before knowing it's you 0 0%
Almost too loud 1 14.29%
Just Right 4 57.14%
Almost too quite 0 0%
No one will hear you coming 0 0%
No one will hear you leaving 0 0%
Voters: 7. You may not vote on this poll
Old 03-03-2009, 07:15 PM   #1
How Loud do you think this will be?
My new exhaust setup is as follows:
Keeping the NA Baffles intact to help reduce noise.
A T60-1 Turbonetics Turbo with a 62mm Turbine.
A RacingBeat large 3" in/out presilencer.
2 Magnaflow 2.5" in/out Mufflers
Just general feelings, doesn't have to be accurate. I'm more concerned about having the LEO's pull me over in Virginia, so general feelings about how loud it's going to be.
Old 03-03-2009, 07:25 PM   #2
Its VA and you have a non-OE exhaust, you'll get pulled over. Just budget for the monthly tickets, lol.
Old 03-03-2009, 07:30 PM   #3
They won't know that. Lol
Old 03-03-2009, 07:58 PM   #4
That its not OE? I tried that. I was with a guy who got pulled over for his factory Racing Beat exhaust in a speed protege. It took FOREVER to convince the cop that it was OEM.
Old 03-03-2009, 08:37 PM   #5
It will not be loud.
Old 03-03-2009, 11:16 PM   #6
Rotary#10
Rotorhead
Rotary#10's Avatar
going for a sleeper look requires some thought before doing. hehe
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 03-03-2009, 11:58 PM   #7
haha, believe me my car is going to look about as sleepy as you can get. Especially with what the exterior looks like.
Old 03-04-2009, 08:07 AM   #8
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Poll option: Cops will already have a road block set up when you arrive.
Old 03-04-2009, 09:09 AM   #9
drewski86
Slow
drewski86 is on a distinguished road
The baffles will only hurt power. The baffle's purpose is to cut the wave as it leaves the port, but wouldn't the turbine wheel do the same thing? With a turbo in the way, I would assume that the difference between baffles and no baffles would be pretty much unnoticeable. My guess is that if there is a difference, it would be when the wastegate is open as there isn't a turbine wheel in the way.
drewski86 is offline   Reply With Quote
Old 03-04-2009, 08:58 PM   #10
Which would happen when i am in pressure (i'm not planning on running that much) at the very most 8psi during the summer. There may come a time later when I push it a little more, but until then the wastegate will probably be open more times than not.
Old 03-04-2009, 11:16 PM   #11
Ender
rotors excite me
Ender's Avatar
While running exhaust gas will always be passing through the turbine, so it will always be muffled somewhat. I'd say remove the baffles, you're really only shooting yourself in the foot because exhaust is easily modified, but once you build the motor with the baffles in place you'll have to rebuild again to remove them.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 03-06-2009, 02:19 PM   #12
I'm already planning on rebuilding this engine so that's not much of a concern. Right now I would like to avoid the possibility of 1) destroying the housing 2) of making unnecessary noise by removing them 3) i'm just plain lazy.
My hope is to have this engine survive long enough while I piece together another one exactly the way I want it. This means radical 6PI porting--I'm currently thinking of a way to port the upper portion of the 6PI and I have a junk iron to find out what the possibility of it is. No Baffles Hi-Comp lightened rotors (RX8 maybe? May stick with NA S4) lightened eccentric shaft. Turbo II housings, aluminum side "irons" and a few other goodies.
What I want from the exhaust however is a system that can be kept in place until I desire to break into the massive horsepower range (will not happen until I'm out of college). I also want it to muffle a majority of the sounds coming from the engine so I don't sound like a little fart cannon machine like this:
http://www.youtube.com/watch?v=X40meUsb2gU
Old 03-06-2009, 04:19 PM   #13
classicauto
crash auto?fix auto
classicauto's Avatar
It won't be very loud.
As long as you're using magnaflows, it won't sound rice.
I'd ditch the inserts IMO. Going to hurt your engine more then removing them will hurt your ears............EGT's man, think EGT's.
Also bear in mind - a factory TII doesn't have the inserts. Is it too loud? (yes I realize it has a stock exhaust at that point too)
