Old 04-08-2012, 01:08 AM   #1
Kush47
Kush47 is on a distinguished road
6 port Bridgeport ???
I hav a 6 port rotary that I want to Bridgeport for a EFI setup. But I haven't seen any templates for this or pictures of it. Can u please post some pics of the correct way a 6port motor is suppose to be bridgeported. Thank you
Kush47 is offline   Reply With Quote
Old 04-08-2012, 07:52 AM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Not sure if this is the right way, but this is the way I did my 1st B-port. It's worked for me so far.
Free-hand.
This motor is actually the result of 2 separate porting projects. The bridges are the latest addition.
IIRC I used a 1/8" drill bit, so I was being very cautious. But Ive heard you can use a 3/16" drill bit?
There are some pictures of what others have done on google, if you type in: Rotary Bridgeport, Bridgeport 6 Port, etc. To give you some idea's.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 04-08-2012, 09:12 AM   #3
RotorDad
Big Ugly
RotorDad's Avatar
Here are a few other BP 6 port plates.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 07-12-2014, 09:20 PM   #4
mfisher12
mfisher12's Avatar
mfisher12 is on a distinguished road
here is my bridge if this is still of interest...just built it about a year ago...runs great! took it to deals gap this past april. its a half bridge on the primarys of the secondary ports, the 5th and 6th are still functional with the aid of RB true dual exhaust. using turbo injectors and tuning with the Rtek 2.1...i do wish that i has used a turbo ecu instead of the s4 na due to lack of a cranking map and fuel correction RPM is limited with the NA ecu
mfisher12 is offline   Reply With Quote
Old 07-12-2014, 09:29 PM   #5
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Very clean looking. Both the porting and the engine.
Old 07-13-2014, 08:35 PM   #6
mfisher12
mfisher12's Avatar
thanks!!
Old 07-13-2014, 02:15 PM   #7
N.RotaryTech
Home-brew Rotary
That's beautiful, mfisher12.
Btw: Little history on mine:
1. 1st time I built my b-port motor it was an S4 na with stock ecu (thats right, got it running on stock ecu!), it got cancer in the form of a rusted through coolant seal track.
2. As of Oct '12 I rebuilt it bigger and better, with addition of: ported primary ports, bigger ported exhaust ports, 9.7 comp rotors, Haltek E6K, 720cc secondarys, & RB header to complete the RB exhaust system.
3. I have over a thousand miles on the motor, I took it to dgrr'13, I haven't been driving it much since, I try to get it some exercise now & then. Still runs.
This fall I want to try driving it more often, I was thinking of getting into drifting, need to swap the diff 1st & get some used tires for the extra wheels I have.
Old 07-13-2014, 08:36 PM   #8
mfisher12
mfisher12's Avatar
thanks!!!!
it was quick on the dragon!! had an EVO trying to out run me and i think it threw a rod or something...wasn't good for him though...shortly after deals gap my diff bushings took a crap so thats the next project...i wish i had done them when i was in there doing the control arm bushings ha ha
Old 07-13-2014, 09:08 PM   #9
mfisher12
mfisher12's Avatar
tried to upload a video but its too big no biggie just idling open header
any way one more of the build and the EVO that didnt make it lol
Old 07-13-2014, 09:15 PM   #10
mfisher12
mfisher12's Avatar
https://www.youtube.com/watch?v=NXWe...ature=youtu.be
just made it available on the you tube
Old 09-10-2014, 11:11 PM   #11
Tougemonster
Meat Popsicle
Tougemonster's Avatar
Tougemonster is on a distinguished road
https://www.facebook.com/video.php?v=10152335809733164
lets see if that works..
facepage link from my brigdy. 15k miles on a stock ecu after eveyone told me it wouldnt work
edit.. i think you have to be signed in to view it.. sorry i didnt get it on youtube before the ex stole my phone
Tougemonster is offline   Reply With Quote
Old 09-16-2014, 07:51 PM   #12
Let's get the facts straight...
I never said it WASN'T GOING TO WORK.
I claimed it wasn't an EFFICIENT SET-UP.
How you define "wouldn't / would work" might not be the same as someone else's definition of the same...
I hear tons of cars...everyday...driving around that sound like shit.
Sure, they will drive up and down the street...
Hell, they might even do a sub-10 second 0-60mph run...
These things are:
1) misifiring
2) eating a lot more gasoline than it should
3) could make more power if tuned correctly
I do not consider cars like these that are driving on the street as being classified as "they work."
I consider them POORLY TUNED and possibly in need of a tune-up.
Put a standalone EMS on it, and I'll put money it'll run faster, quicker, and better than your current stock ECU set-up...
Old 09-16-2014, 07:01 PM   #13
almoststockfc
almoststockfc's Avatar
Miles!! Are you ever going to tell me how you get everything that clean?!
-75 RE_W_PU -
