-   -   6 port Bridgeport ??? (https://rotarycarclub.com/showthread.php?t=15656)
Kush47 04-08-2012 01:08 AM
I hav a 6 port rotary that I want to Bridgeport for a EFI setup. But I haven't seen any templates for this or pictures of it. Can u please post some pics of the correct way a 6port motor is suppose to be bridgeported. Thank you
N.RotaryTech 04-08-2012 07:52 AM
:lol: Not sure if this is the right way, but this is the way I did my 1st B-port. It's worked for me so far.
Free-hand.
This motor is actually the result of 2 separate porting projects. The bridges are the latest addition.
http://i184.photobucket.com/albums/x...h/DSC_0019.jpg
http://i184.photobucket.com/albums/x...DSC_0026-1.jpg
IIRC I used a 1/8" drill bit, so I was being very cautious. But Ive heard you can use a 3/16" drill bit?
There are some pictures of what others have done on google, if you type in: Rotary Bridgeport, Bridgeport 6 Port, etc. To give you some idea's.
RotorDad 04-08-2012 09:12 AM
Here are a few other BP 6 port plates.
http://i597.photobucket.com/albums/t...esCAF8X3SU.jpg
http://i597.photobucket.com/albums/t...esCAIEP6VC.jpg
http://i597.photobucket.com/albums/t...esCAWR8QEL.jpg
mfisher12 07-12-2014 09:20 PM
3 Attachment(s)
here is my bridge if this is still of interest...just built it about a year ago...runs great! took it to deals gap this past april. its a half bridge on the primarys of the secondary ports, the 5th and 6th are still functional with the aid of RB true dual exhaust. using turbo injectors and tuning with the Rtek 2.1...i do wish that i has used a turbo ecu instead of the s4 na due to lack of a cranking map and fuel correction RPM is limited with the NA ecu
GySgtFrank 07-12-2014 09:29 PM
Very clean looking. Both the porting and the engine. :biggthumpup:
N.RotaryTech 07-13-2014 02:15 PM
That's beautiful, mfisher12.
Btw: Little history on mine:
1. 1st time I built my b-port motor it was an S4 na with stock ecu (thats right, got it running on stock ecu!), it got cancer in the form of a rusted through coolant seal track.
2. As of Oct '12 I rebuilt it bigger and better, with addition of: ported primary ports, bigger ported exhaust ports, 9.7 comp rotors, Haltek E6K, 720cc secondarys, & RB header to complete the RB exhaust system.
3. I have over a thousand miles on the motor, I took it to dgrr'13, I haven't been driving it much since, I try to get it some exercise now & then. Still runs.
This fall I want to try driving it more often, I was thinking of getting into drifting, need to swap the diff 1st & get some used tires for the extra wheels I have.
mfisher12 07-13-2014 08:35 PM
thanks!!
mfisher12 07-13-2014 08:36 PM
thanks!!!!
it was quick on the dragon!! had an EVO trying to out run me and i think it threw a rod or something...wasn't good for him though...shortly after deals gap my diff bushings took a crap so thats the next project...i wish i had done them when i was in there doing the control arm bushings ha ha
mfisher12 07-13-2014 09:08 PM
2 Attachment(s)
tried to upload a video but its too big no biggie just idling open header
any way one more of the build and the EVO that didnt make it lol
mfisher12 07-13-2014 09:15 PM
https://www.youtube.com/watch?v=NXWe...ature=youtu.be
just made it available on the you tube
Tougemonster 09-10-2014 11:11 PM
https://www.facebook.com/video.php?v=10152335809733164
lets see if that works..
facepage link from my brigdy. 15k miles on a stock ecu after eveyone told me it wouldnt work
edit.. i think you have to be signed in to view it.. sorry i didnt get it on youtube before the ex stole my phone
almoststockfc 09-16-2014 07:01 PM
Miles!! Are you ever going to tell me how you get everything that clean?!
RETed 09-16-2014 07:51 PM
Let's get the facts straight...
I never said it WASN'T GOING TO WORK.
I claimed it wasn't an EFFICIENT SET-UP.
How you define "wouldn't / would work" might not be the same as someone else's definition of the same...
I hear tons of cars...everyday...driving around that sound like shit.
Sure, they will drive up and down the street...
Hell, they might even do a sub-10 second 0-60mph run...
These things are:
1) misifiring
2) eating a lot more gasoline than it should
3) could make more power if tuned correctly
I do not consider cars like these that are driving on the street as being classified as "they work."
I consider them POORLY TUNED and possibly in need of a tune-up.
Put a standalone EMS on it, and I'll put money it'll run faster, quicker, and better than your current stock ECU set-up...
