Old 05-29-2009, 10:50 PM   #1
bbade
bbade's Avatar
Shot pillowballs - harmful?
So my pillowballs are pretty well shot, I plan on replacing them this summer. I am going to bring the 7 out to Indiana for the summer, so i'm looking at a 700 mile drive.
How critical is it that the pillowballs be replaced, can I do this after the move when I have time to do it myself or should I have them replaced prior to the drive?
Old 05-30-2009, 12:24 PM   #2
ZGN
Administrator
ZGN's Avatar
My rear ones were shot for over 2 years with no Ill effects other than a clunk clunk when braking, or accelerating from a stop to start and sometimes between low rpm shifts and when you let off the throttle in gear. If you plan on drag racing you car it is possible that would could create further damage by extermely hard launches. It could possibly cause uneven wear on your tires.
Kevin
Old 06-15-2009, 05:58 PM   #3
ZachFD
ZachFD is on a distinguished road
they can lead to snap oversteer if your rear wheels are able to move left/right
ZachFD is offline   Reply With Quote
Old 06-15-2009, 06:01 PM   #4
albertomg
Huh?
93 Vintage Red R1
Power: Street Ported Motor, 99 Twins, V-mount, DP>SMB cat/MP> RB cat back, PFC, 1300cc secondaries, Fuel Pump, ACT clutch, RB lwfw, etc
Steve Kan tuned - 310rwhp at 10PSI
Suspension: Tripoint custom valved Koni + Ground Control coilovers, Eibach sway bars, SuperPro bushings, Corner Balanced and accurately aligned
Brakes: RacingBrake 4 corner BBK
SSR Integrale 17"x9" +45, Dunlop Star Specs 255/40
Old 06-15-2009, 06:53 PM   #5
bbade
bbade's Avatar
Update - I made it to Indiana with no issues.
I had never taken the 7 on a trip this long and let me say it performed beautifully. Absolutely magnificent car, just another nail in my rotary coffin .
Old 06-15-2009, 10:18 PM   #6
ZachFD
Originally Posted by albertomg View Post
Huh?
if you jack up the car and grab a rear wheel and try to move it left/right...on a car with really worn bushings it will click left and right a few centimeters. If the rear end steps out on you, and you overcorrect or something and put alot of force one of the rear corners, worn bushing can cause the wheel to toe out and contribute to snapping the car around.
Old 06-16-2009, 12:39 PM   #7
albertomg
That example is more useful in determining play in the wheel bearings.
If the rear steps out on your, talent (or luck) is what is going to save you.
Not all the bushings affect toe so your example is a bit presumptuous. Worn bushings will feel sloppy and lack precision which can cause various handling issues depending on which bushing it is.
Understand that I'm not trying to bust your chops. Just trying to broaden your understanding/interpretation. For the OP, he was just taking a long cruise so the effects of driving on worn pillowballs are minimal.
93 Vintage Red R1
Old 06-17-2009, 12:36 PM   #8
ZachFD
I guess I wasn't too clear.
I didn't mean that worn bushings will always lead to this scenario. My car has worn bushings in the rear that pop and clunk and in the front as well. However, the car doesn't have any alignment/toe problems/instability, but I have heard of it happening depending on the severity of a particular bushing.
