Old 07-26-2009, 09:50 AM   #1
rx7mechusa
no no come on start plz?!
rx7mechusa's Avatar
rx7mechusa is on a distinguished road
Ok ill keep that in mind about the apexi exhaust and once i can get under the car again ill look to see how it'll fit and were i need to hack it off at. Ill start looking around for some 1600's. what is the max i can get to on stock injectors until i can locate some better ones? say 225-250 ish? again i am only shooting for 300 and was also wondering about doing a greddy intercooler pipe kit and using a regular IC? what do you think of that?
rx7mechusa is offline   Reply With Quote
Old 07-26-2009, 09:24 PM   #2
Check out the rx7.com fuel injector calculator here:
http://rx7.com/cgi-local/2ndgencalc.cgi
Keep in mind that the resulting numbers are BHP FLYWHEEL HP numbers.
Knock off 15% for most DynoJet numbers.
550 + 720 will get you maybe 250hp at the rear wheels.
I dunno where you can get just the GReddy IC pipes?
GReddy only sells full kits.
You might get lucky finding someone parting their kit though...
