Old 06-15-2009, 10:55 PM   #1
ZachFD
ZachFD is on a distinguished road
Originally Posted by jvallo7 View Post
I just bought a very clean 88 good shape yada yada 2day a swaped the old plugs out and did the water de-carbon trick and now it has a chatter @ low rpms but smoothes out after 2500rpms could i have blown a apex? or got some carbon stuck?? the motor had good power b4 and didnt seem weak??
just pull the plugs back out and crank the motor over. If you hear even chugs then its probably just a spark issue that got messed up when you went to change plugs. You probably didn't plug the wire in all the way.
Check your ignition system, might have a cracked plug wire...etc. You could have gotten water on something under the hood and shorted something out etc.
Bottom line is, check the vaccuum on the engine or pull out the plugs and listen to the consecutive chugs. If its chug,chug.....chug,chug......chug,chug then you threw a seal.
ZachFD is offline   Reply With Quote
