Old 04-08-2009, 11:56 PM   #1
Still, the MS miatas are bad themselves....no point in taking the motors out of them.
I don't understand the point of swapping for equal or less power. All that work for the same or worse power to weight.
And isn't the MS 180hp?
Old 04-17-2009, 05:38 PM   #2
rotaryextreme
i like spinners
rotaryextreme's Avatar
rotaryextreme is on a distinguished road
Seriously, if your considering to go with a 4 cylinder.
20 valve 4age N/A, or an (stock 210-215) sr20ve-yes VE, there is a mechanical vtec version of the sr20de motor. Those are 2 good very affordable N/A motors.
You want reliableish turbo power, sr20det.
Those will be worth the hassle and your time.
And once the renesis get cheaper, that will be a slamin swap for an all motor FC, and it can be legalized because it is a newer motor of the same type. State ref will pass you.
My 2 cents.
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08.
rotaryextreme is offline   Reply With Quote
Old 06-01-2009, 12:41 PM   #3
lcrotaryracer
lcrotaryracer is on a distinguished road
going to a 4.3 vortec. got a good deal on the engine. so im going to go that rout
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 06-02-2009, 06:24 AM   #4
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
i've also considered that swap, figured I might do that if i hang on to the GTU and the engine decides to die...
Old 06-02-2009, 10:14 PM   #5
lcrotaryracer
the good thang is that its not to bad on the pocket. the bad finding a t5 trans. u can put some good power to the ground . im looking around 300hp all moter.
Old 06-08-2009, 04:57 PM   #6
Rotary#10
Rotorhead
Rotary#10's Avatar
why not just swap a 13bt into a miata. that be awesome! Im pretty sure its been done.
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
