Old 01-10-2010, 10:46 AM   #1
Dimensionally that looks pretty good - I cant tell how tall they sit near the headliner, but I'll check it out at DGRR. Seats do match the interior well...
Thanks Bill, yeah I'm liking them alot so far
Originally Posted by FC3S Murray View Post
Not bad Brian...not bad. They must feel WAY better then the stock worn out seats.
Is that passenger seat bolted down?? It looks like it sits cock-eyed a bit...
So you are planning on running different seats for racing or all together??
I LIKE the center window switch set up, very cool like a BMW!!
They are better than the stockers, but I was running some corbeaus. Those were nice, but not the greates for scooting around town or long trips. I'll swap the corbeaus in for track days. 8 bolts, 10 minutes, best of both worlds.
It's bolted down, but becuase of the passenger side floor pan, it sits higher than the drivers. All of them do it, I think the stockers are the only ones that sit at about the same level.
Originally Posted by BigIslandSevens View Post
I would guess that the seat is bolted down. The FC and FB have a clever system that mounts the inboard rail a couple inches higher and on an angle with the trans tunnel. This makes it almost impossible to mount a seat properly, as the Adjustment is built into the seat frames mounting.( stock)
When I put the FD seats in the FB I ran into the exact problems as he did. The seats are just not dimensionally close at all. IMO. The bottoms of the seats drop down low which in turn causes the higher seating. For me at 6'2 that doesn't work well in the FB.There is o way I can get my helmet on and fit inside the car. I found that S4 seats are a direct bolt in on the passenger side. The donor car I used did not have drivers side seat rails so I made the FB rails work. I have come to hate installing seats
Yeah it is a PITA. In the Corbeaus I had to slouch a little with the helmet. A problem that I plan on rectifing over the winter. Something about having to slouch while racing doesn't really agree with me.
Old 01-10-2010, 03:36 PM   #2
Tech B
Tech B is on a distinguished road
That is a nice power band, I bet that car is fun.
Tech B is offline   Reply With Quote
Old 01-10-2010, 09:04 PM   #3
helghast7
F yo couch!
helghast7's Avatar
helghast7 is on a distinguished road
hey Brian, ive been thinking about the item you were talking about on saturday and ive been doing some digging
i cant find shit about it, i found the theory on it, that it was produced, but nothing current, were to buy one, or any kind of specs
if you have some shoot me some links because ive been at it for a good 3 hours lol
i would love to try it out, but after reading the theory it had me a bit concerned with how reliable they are
hehe i bet everyone is scratching there heads on what im talking about
87' n/a FC
94' FD-360whp, 300lbs-tq at 14psi on twins
92' ZZR-600 sold
07' CBR600RR
more to come
helghast7 is offline   Reply With Quote
Old 01-11-2010, 12:37 PM   #4
Sooo.....Brian. How much do you figure to replicate those RX-8 seat brackets once you have them sorted out?
Seriously!
Old 01-11-2010, 04:16 PM   #5
Yeah she is, if I can keep traction. There's non in 1st or 2nd on low boost, and highboost breaks them loose in 3rd. I dunno if it's the cold roads or what but I can't keep the ass in line when I mat her. I gotta stop driving this car and get to work on her.
I'm sure they are. The only place to find any real information on them is the manufacturers website. It's not under the general listing though, you need to DL or open thier PDF catalog. Everything else I've found is really just internet heresay, nothing really concrete as it applies to gas engines ..... everyone still guessing
Seriously!
Honestly, not that much at all. The only problem is they can't really be bolted in. They really should be welded in mainly becuase of the passenge side inboard front bracket being flush with the floorpan. The passenger outboard front, drivers outboard rear and both drivers front mounts are a piece of cake. It's also the rear inboard bolt on both that cause a huge problem. I don't know if the track can be cut or not and still allow full adjustment rearward. I'll have to figure that out when I start into the car..... which should be today but it won't be My solution is to change the mounting entirely on the rear inboard mounts so that the bolt drives through the rack downward. I'll make installation a TON easier as well regardless of the seat that I use. But that requires a steel box with a nut welded on the inside and welding it to the floorpan. Not something that everyone is up for as the prep would take wuite some time to clean off all the heat material, grind the primer down to bare steel, weldthrough prime everything, weld it, seal it etc etc. It's a cake walk with the car at my shop..... too bad all you guys live so damn far away from CT, well, alot of you.
I could duplicate the mounts that I bulit for mine with the exception of the inboard rears fairly cheaply, but they would need to be welded to the RX8 tracks, or bolted. I prefer welding honestly. Maybe $125 for 6/8 mounts, or if I find that the rear inboard track can be cut and the factory bolt holes used we can figure something out.
Old 01-11-2010, 08:10 PM   #6
helghast7
F yo couch!
helghast7's Avatar
yea thats as far as i got, the companies site only formally addresses the item for one car, but it looks like it would only work on that specific car
all other sites speak of it in past tense and dont say how to go about purchasing one or the type of setup they would run
and lol im trying to make this go as long as possible lol its getting hard
87' n/a FC
92' ZZR-600 sold
07' CBR600RR
more to come
Old 01-12-2010, 09:44 AM   #7
Talking Oh noes!!!!! I done it again!
The super secret tranny is assembled, it works, sorta, one problem to solve and one piece to be machined. Then it's off to Daves for some cryo treatment, full rebuild and then it can be put into the car. 6-spd, awesome gearing, and it fits in the stock shifter opening and BOLTS up to the bellhousing.
Old 01-11-2010, 05:13 PM   #8
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
Brian,
Let me know if I can help you with those brackets. We laser cut and CNC press brake metal everyday here. Thos e brackets could be bolted in if you used a square frame and press brake the ends. We could even powder coat the assembly in house. If you want, let's talk more through PM. We have in-house CAD design as well.
Todd B.
(formerly NoLimitInd)
Old 01-12-2010, 10:23 AM   #9
Roen
Evil Club Mod
Roen's Avatar
Curiouser and curiouser.......
Old 01-12-2010, 02:45 PM   #10
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I lol'd.
Old 01-12-2010, 05:01 PM   #11
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
You should have done it as Count von Count from Sesame Street......
btw, where's mine?
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
Old 01-12-2010, 05:08 PM   #12
need RX7
Clean S4 Nutswinger
need RX7's Avatar
*awaiting new video with said revisions*
Old 01-12-2010, 07:30 PM   #13
helghast7
F yo couch!
helghast7's Avatar
nice dude, cant wait to see it in the car
87' n/a FC
92' ZZR-600 sold
07' CBR600RR
more to come
Old 01-12-2010, 07:48 PM   #14
That vid make me LOL at work today.
Old 01-12-2010, 08:23 PM   #15
btw, where's mine?
If you're serious, I can price some pieces out for you. I know exactely what needs to be done to make it work, and can get prices for everything with the exception of the machine work. I'll be heading down to the shop in the next few days to get some parts turned down.
Only drawback so far is there is no aftermkt short throw that I can find for it..... I may be making one of those too
