Old 05-05-2009, 06:56 AM   #1
Shadow24v
Shadow24v is on a distinguished road
lol, maybe i can do a quick and dirty rebuild, gaskets and oil control rings. it seems to run fine other than smoking up a storm
probably won't get to change the MOP over til the weekend though
Shadow24v is offline   Reply With Quote
Old 05-05-2009, 10:35 PM   #2
NoDOHC
NoDOHC's Avatar
Just read the FSM, if everything is in spec according to that, put it back in. (It is only fair to warn you that apex seals are $70.00 each at the dealer and should be replaced if out of spec.)
Old 05-06-2009, 11:07 AM   #3
TehMonkay
rotaryaviation.com
Make sure you get their race apex seal springs or some oem mazda ones though.
Old 05-13-2009, 08:40 AM   #4
Shadow24v
well, ive been thinking:
if the MOP isn't the problem and im going to have to pull the motor apart to do oil seals, i was wondering if i could switch to S5 N/A E-shaft, counterweights and rotors and the S5 VDI intake while retaining S4 electronics and computer.
I ask as there is an S5 N/A in the local J-yard that i was thinking of snagging for spare parts like irons and rotor housings, but if i can get the lighter higher compression rotors and the better intake while im at it, why not?
is this feasible or am i out of my mind? lol
Old 05-13-2009, 12:40 PM   #5
TehMonkay
Yeah, it's possible, as long as you don't need emissions, then it's a little trickier. Only thing you'll have problem with is the S4 water temp sender won't fit in an S5 NA iron and the s5 sensor displays the wrong temp so you'll want an aftermarket gauge.
Old 05-13-2009, 02:46 PM   #6
Shadow24v
ahh, ill have to keep that in mind. depending on whether the S4 irons are ok or not, the S5 internals will fit regardless right?
Old 05-13-2009, 03:55 PM   #7
My5ABaby
My5ABaby's Avatar
There's no way the OMP is causing that. Even stuck wide open the amount of oil they inject is minimal. According to the FSM it's up to .25cc/2000rpm/5 minutes. Even stuck open and forcing more through due to pressure I can't see more than 1 cc/2000rpm/5 minutes.
Community Service Manual
RotorWiki
