Keep in mind guys - as it always in when premixing anything (cars, bikes, lawnmowers, etc) you add the oil to the tank FIRST and then add the gas... otherwise it won't mix evenly. You use the pressure from the gas pump to slosh the oil around and mix properly.
If you are using the stock OMP you really wont need more than 3 to 5oz like others have mentioned. Going more than 100:1 is a bit much.... |
Rep Power: 20 ![]() |
[QUOTE=WE3RX7;63559]Keep in mind guys - as it always in when premixing anything (cars, bikes, lawnmowers, etc) you add the oil to the tank FIRST and then add the gas... otherwise it won't mix evenly. You use the pressure from the gas pump to slosh the oil around and mix properly.
I add my pre-mix last. My theory is, the fuel return will circulate the mixture. I use Johnsons-Evinrude from Wal-Mart.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
Bookmarks |
