Old 07-20-2008, 09:42 AM   #1
warwickben
sa rat rod
we can do it. i was thinking the same thing instead of the respeed kit. since i have had ball joint problems ect.
theres a week spot on mustang 2 front end but its a easy fix. ill try to find the mag i have that explain the problem and how to fix it. i mite not have it tho sice i cleaned the house out. the good thing about this set up is you dont need the shock tower any more since it uses a upper and lower control arm. well from that kit pictured i think you would need to ill go look for the kit for you. whats new with the motor i gave you?
