Old 07-26-2016, 09:32 PM   #1
chibikougan
chibikougan's Avatar
Looks like it may have had some fusible links so they put in a relay.
Old 07-26-2016, 09:48 PM   #2
chibikougan
There is a blue and yellow that go into the cab for the:
Ignition
Alt Warning Light
a-10 connector...
Old 07-26-2016, 09:56 PM   #3
chibikougan
It looks to be a regulator for the alternator... from the 79 wiring diagram.
Old 07-26-2016, 10:05 PM   #4
chibikougan
Yeah Voltage Regulator...
http://www.rx7club.com/1st-generatio...pgrade-967330/
Old 07-27-2016, 12:12 AM   #5
FC Zach
FC Zach's Avatar
Most parts stores have the ability to bench test alternators, whether or not this test can be done with your application, I don't know but it's worth a shot.
My guess is the regulator but I'm not familiar with the first gens and their parts.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 07-27-2016, 12:19 AM   #6
FC Zach
FC Zach's Avatar
As for the gauge. . . Move the yellow signal wire to the Trailing coil and see if there is no change to confirm that you don't have a defective coil. A failed Leading coil is one reason for a dead tach.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 07-26-2016, 10:58 PM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Ignition
Alt Warning Light
a-10 connector...
Yeah, I see it now. The YL (yellow/blue) wire runs from the "L" terminal on the external voltage regulator to the alternator warning light but is also connected to the oil level warning light, coolant level warning light, and tachometer circuits. It's still a question of whether it's the alternator or the voltage regulator and I still don't know how to test them. The only thing I've been able to verify is the is the L terminal doesn't have continuity with the A and S terminals, but does with the others, which is consistent with the wiring diagram. I'm going to dig into the display more tomorrow to see if I can't find a short somewhere.
